If you don't have a 'network' (network dataset or geometric network), then for schematics to use the data, you have to define the connectivity. So for your schematic link feature classes, you must create the OriginNode and ExtremityNode attributes and point them to fields (or a script attribute, function attribute etc... can be used) that contain the connectivity information. This is basically like doing a custom query type of diagram because there isn't a real network to give schematics the connectivity information and therefore you have to use attributes to do it.
