ArcGIS simply makes the call to the Oracle client which would be the first one in the library path as the DLL is loaded.
[INDENT]System PATH SDE direct connect string Result 10g path;11g path sde:oracle10g Connection Succeeded 10g path;11g path sde:oracle11g Connection Succeeded 11g path;10g path sde:oracle10g Connection Succeeded 11g path;10g path sde:oracle11g Connection Succeeded 10g path sde:oracle10g Connection Succeeded 10g path sde:oracle11g Failed: Server library could not be loaded 11g path sde:oracle10g Failed: Server library could not be loaded 11g path sde:oracle11g Connection Succeeded[/INDENT]
I guess it is likely ArcCatalog tried both Oracle clients (10g and 11g)
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
