Is It Possible to get dictionary renderer symbols and use it in Datagridview or list. Suppose i have a stylx file where i was able to renderer the symbols by using attributes. Is this symbols can be used to data grid view and list
Thanks for the reply.
I would like to get every symbol in style and add it to the list grid and also based on quick accessing I would like to get the recent symbols on top of the list.
Regards
G N Sharan Sai
Hi!
Do you want to render each symbol primitive in the style and add it to a list or grid? Or do you want to display symbols generated from the style for a particular feature (set of attributes)? To get the symbol for a set of attributes, use DictionarySymbolStyle.GetSymbolAsync. For searching symbols by category, etc. see DictionarySymbolStyle.SearchSymbolsAsync (you can then iterate the results).
You can find some good examples in the samples:
- Read samples from a mobile style (see the GetCurrentSymbol function for getting a symbol for a set of attributes and ReadMobileStyle for an example of iterating all symbols in the style)
- Custom dictionary style - an example of using a custom dictionary style
I hope that helps!
Thad
