The first beta of the next generation ArcGIS API for JavaScript is now available.
ArcGIS API for JavaScript 4.0 beta 1 - available today | ArcGIS Blog
Bjorn Svensson,
Just looked at the blogpost and reading through the documentation, it looks all very exciting.
One thing I would point out as being important for long time developers is the following:
Prior to 4.0, you could use both AMD and legacy modules. Beginning with 4.0, support is only provided for the AMD model.
So everybody check this out http://blogs.esri.com/esri/arcgis/2013/10/14/the-abcs-of-amd/
Tim
I am already trying to get pro scenes going so I can create 3D buildings.
Scene Layer | ArcGIS API for JavaScript
Bjorn,
On thing I find annoying/different right off is that the map only reacts to the mouse wheel on the fourth click/roll of the mouse wheel. Where as in the 3.x API every roll/click of the mouse wheel caused a zoom in/out. Is this configurable somewhere and I am just overlooking it?
Am I missing something? Can you not add a kmlLayer in the 4.0 beta? I don't see KMLLayer as a layer type in the API reference.
Steve Cole - you are correct, in beta 1, the KMLLayer isn't supported. This is the first of several betas, and many classes are not yet available, but will be available in later betas. As mentioned on the beta home page and the blog post - the first beta is primarily a developer preview with limited functionality.
Makes sense, thanks!
Robert Scheitlin - that's a beta 1 bug in the MapView. Try it in SceneView and you should see the behavior you're used to.
That's still a bug in Beta 2
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
