No the domain is not associated with the field. the field type is long and the domain field type is entier longWhen i verify the list of coded value domain in the database with the tool 'Domain Sort' the domain appear.
re good morning i tried manually associating the domain with the field in ArcCatalog but in the dropdown list of doamin didn't work it's locked so i can't associate the field with the domain.note i have implemented the geodatabase in the DBMS (sqlqerver) with CASETOOlThank you
"In order for the domain to appear in ArcMap, it needs to be associated with the field. Can you try manually associating the domain with the field in ArcCatalog and test if that allows you to see the domain dropdown in ArcMap? "
yes i tried associate it manually and it work. but it didn't work on the table having subtypefield.
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
