I had forgotten all about the post, but sadly it does not look like I had any responses. However in retrospect - the data I had (500,000) records, would have been way to big to load on the client all at once. You may be able to draw the polygons once with D3 - then change the colors by manipulating the svg client side. Then for large data, make calls to retrieve smaller groups at a time and build a buffer for a smoother client side exp.
Thanks, Melanie.
