The window ???zoom in??? and ???zoom out??? are missed in the ???map extent??? mode ...
Hi Jamal,This is correct and by design. In the first screen capture you provided, it shows the Preview tab of the ArcGIS Viewer for Flex application builder, which shows the navigation widget.In the second screen capture you provided, it shows the Maps tab - which is not meant to display the navigation widget. You can still define a spatial extent bounding box on the tab by simply holding down the Shift key as you left mouse click to zoom in/out.Hope this helps,
