I wanted to find out if you have used the latest version of HEC-GeoHMS 10.0.0.85. I previously had Arc Hydro 2.1.0.98 and had to uninstall it as HEC-GeoHMS 10.0.0.85 wants Arc Hydro 2.1.0.30. Once I had uninstalled Arc Hydro 2.1.0.98, I was able to install HEC-GeoHMS and ArcHydro. I've come accross two problems, the first is that if you add HEC-GeoHMS toolbox to ArcCatalog Toolbox it crashes ArcCatalog and the only way to get ArcCatalog to open without crashing is to delete the Normal.gxt. The second problem that I've found is that if you run Adjoint Catchment from the toolbox or within ModelBuilder the output is always empty. Just wondering if you have come across the following.
That would be ftp://RiverHydraulics:river.1114@ftp.esri.com/ArcHydro/Setup10.1/ from a web browser.Far more efficient to use an FTP client (FileZilla perhaps) with these login credentials:[INDENT]ftp.esri.comlogin: RiverHydraulicspassword: river.1114As provided for the initial ArcHydro 2.0.x version here: http://forums.arcgis.com/threads/8274-ArcHydro-in-ArcGIS-10?p=35289&viewfull=1#post35289[/INDENT]Stuart
Here is the new link:https://mft.esri.comLogin: ADSRiverHydraulicsPassword: ADSRiver.2012Christine DartiguenaveEsri Water Resources Team
I was excited to see a new version of ArcHydro, hoping that it would solve the problems I've been having. No such luck; if anything it seems even glitchier. Every ArcHydro tool or command I try to run results in error messages and no output. I'm wondering if any others are experiencing similar problems.thanksmn
I am also in need of an update for ArcHydro that can be used in ArcGIS 10.1. I just tried to install using the latest, that I could find, ArcHydro installer and got an error saying that ArcGIS 10 wasn't installed on my system. I tried downloading from the FTP site and the website (http://resources.arcgis.com/content/hydro/surface-water/about) with no success.TIA,Paul
Current password is ADSRiver.2014b
Christine
