I had similar issue whilst running customised application on ArcGIS 10.0 on Win 7 upgraded pc's. With reasonable testing, I have requested our IT support to enable full control on cdrive settings and tweaked a bit with group policies.
I had no issue running on XP as all users have access without any limitations which is not the case with Win 7.
Also, suggest to check environment settings.
Hope this helps
Drew,
a search on support.esri.com only returns this thread. I got the information through my local Esri software distributor. Maybe you can get more information by opening a support incident at Esri.
Fridjof
I'm looking for documentation on this bug to send to my IT department but I can't find it listed anywhere, do you have a link or is ESRI still keeping it a secret?
This was my problem as well, thanks for the suggestion. In my case IT had just set MS Forefront Endpoint Protection to do a full system scan Thursday afternoons, right when I started getting this error. The same script runs without issue any other time.
Hi All,I am having the same issue and it's random. [...] Due to govt policy I am not able to remove/add anything and I am hoping that there is an easy solution. Thank you Allison
This didn't help in my case. Instead, I learned that I had to exclude the FGDB path from being scanned by MS Security Essentials. There seems to be a bug #NIM088911 "When using background processing while Microsoft Security Essentials is running real time protection, the process fails. By either turning off background processing, OR turning off Microsoft Security Essentials, the process works.", but the bug document is only visible to ESRI (and the NSA of course). Why?
Next day...Thanks to the ESRI team for addressing my issues. Opening the database folders in Windows Explorer, clicking on the 'Properties' tab and un-checking the 'Read-only' radio button, then applying it to all folders and sub-folders has helped me continue projects without that annoying message!
