I have a bunch of (my) content that I want to mark as authoritative and delete protect in Portal 10.6.1. I see that there is an API for delete protect https://developers.arcgis.com/rest/users-groups-and-items/protect.htm is there something similar for mark as authoritative? And can this be done with Python?
Looking for a python way to do this on thousands of items at once. ...
I see with https://community.esri.com/thread/220209-set-data-item-as-authoritative-with-api-for-python I can do it one item at a time....how to do on all items say, owned by Sasquatch? While I'm on this thread, how to assign the same number of items to a single Category, at once?
Thousands???
Get a list of all your item id's Put them in an Access table
Copy the python script to a new Access Table. Two tables one that is thousands and one that is just the script.
Change the script so that the variables match your environment. other than <item id>
Add to the bottom of the script
del gis
del item1
this does not delete the gis or the item it just deletes them from the running python script so they can be used 1000's of times.
add both tables to a create query session. add the long one as the first field ad the script as the second field. Then do a make table. This will create a new table that has your id's on the left and the script on the right.
Then make another query to replace the
<SPAN class="" style="color: #669900; border: 0px; font-weight: inherit;"><item ID></SPAN>
with the value from the left column.
Thomas, we have been having some issues with 10.9.1 and overwriting services. I believe you are looking for something like this:
import arcpyfrom arcgis.gis import GISobjGIS = Nonedef msg(message):arcpy.AddMessage(message)returndef updateProtection(condition, item_id):msg(f'Updating settings for {item_id}')try:objGIS = GIS(gis_url, username, password)except Exception as e:msg(e)try:for i in item_id.split(";"):item = objGIS.content.get(f"{i}")if condition == "enable":item.protect(enable = True)item.content_status = 'org_authoritative'else:item.protect(enable = False)except Exception as e:msg(e)returnif __name__ == '__main__':gis_url = arcpy.GetParameterAsText(0)username = arcpy.GetParameterAsText(1)password = arcpy.GetParameterAsText(2)item_id = arcpy.GetParameterAsText(3)condition = arcpy.GetParameterAsText(4)updateProtection(condition, item_id)msg("complete")
this article was super helpful to me figuring out how to mark a single item authoritative and enable delete protection via the API from one of Esri Community's newest MVPs, @Clubdebambos !
I'd recommend using search to narrow down your thousands of items by item type, then the for/in loop below to enable delete protection and mark as authoritative on each item in your list.in the Python Window of ArcGIS Pro 3.4 / ArcGIS Enterprise 11.3:
items = gis.content.search(query='',item_type="xyz",)len(items) # to get count of items in listfor item in items: item.protect() item.content_status = "authoritative"
additional search references:
How To: Find specific items using queries in the arcgis.gis module with ArcGIS API for Python
Accessing and creating content via the API (be sure to read the "About search" section)
