I had the same problem. Use the edit tools to move you outlet and snap it to the very edge of the sub-basin where the river feature intersects the sub-basin layer. Errors related to the outlet point should then be cleared.
I have re-checked my model multiple times, but am unable to export the basin model file. While checking HEC-HMS data, I get the following error:
End of checking point: name=Outlet1 oid=1 - PROBLEM: outlet point does not have right river connectivity.
This is the only error I have in the model. I checked the outlet and found that it was exactly on the stream. I do not know how to move the outlet and am unable to find a solution for the error.
While exporting the basin model file I receive the RESULT_FAIL from a call to a COM component.
Please help me!
Any other suggestions?? Outlet point for my project is lying exactly on top of river.ThanksAjay
