I was wondering if i can put a password (User Level) in the ARC map editor? in which other users cant do editing and other users can only edit some geodatabase? or there is an other way around with this kind?
Is this a local install or a network install? How is access to the data controlled?
Access to data is through Network (Server Data) and the ArcMAP is in each Desktop of the persons in charge.
i would like to make the data to have a password which Person A could only do the Data A..
There is a whole load of stuff in the help topics using ... edit permissions ... as a key phrase search. Really depends on what you are doing. for example... Alter permissions—Help | ArcGIS for Desktop
I dont have ArcGIS server and SDE, We only have in the office is the ArcGIS for Desktop.
is there any other way around for me to lock my database for being edited by other ArcGIS Viewer/User in our network?
You would have to talk to your staff about restricting access to your data probably in a restricted folder. But this is of little use, if others have to use it
if i restrict my data folder, would other user could still view it on their ArcMAP?
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
