Currently my story map cuts off some of the information. How do I make it so it has a scroll bar on the side?
Hi Chaya,
There are a couple of ways you can approach this:
1) You could add the following line to the #info CSS:
overflow-y: auto
2) There's a setting in the config called popupHeight. You could increase that value if you want to lengthen that display area and avoid the overflow altogether.
Hope this helps!
Lee
I added the line to the #info CSS and it worked! Thank you!
