fc = r"D:\csny490\temp\road_pnts.shp" pntDict = {} dsc = gp.describe(fc) shapeFieldName = dsc.shapefieldname oidFieldName = dsc.oidfieldname searchRows = gp.searchcursor(fc) searchRow = searchRows.next() while searchRow: shapeFieldValue = searchRow.getvalue(shapeFieldName) oidFieldValue = searchRow.getvalue(oidFieldName) centroidValue = shapeFieldValue.centroid xValue = centroidValue.x yValue = centroidValue.y if (xValue,yValue) in pntDict: pntDict[(xValue,yValue)].append(oidFieldValue] else: pntDict[(xValue,yValue)] = [oidFieldValue] searchRow = searchRows.next()
def shapeToPoints(a_shape,theType,arcpy): ''' pnts = shapeToPoints(a_shape, shape type, geoprocessor) Purpose: Converts a shape to points, the shape and its type are passed by the calling script Requires: def pntXY(pnt) ''' outList=[] part_num = 0 part_count = a_shape.partCount if theType == "Multipoint": #Multipoints while part_num < part_count: pnt = a_shape.getPart(part_num) XY = pntXY(pnt) if XY not in outList: outList.append(XY) part_num += 1 else: #Poly* features while part_num < part_count: #cycle through the parts a_part = a_shape.getPart(part_num) pnt = a_part.next() while pnt: #cycle through the points XY = pntXY(pnt) if XY not in outList: outList.append(XY) pnt = a_part.next() if not pnt: #null point check (rings/donuts) pnt = a_part.next() if pnt: XY = pntXY(pnt) if XY not in outList: outList.append(XY) part_num += 1 return outList
