Dan McCoy
Yes, there have been changes here and what you want is possible.
When the Admin deletes a member from the Organization, if Esri Access is enabled, the account will convert to a personal (public) account. If Esri Access is NOT enabled, then the member will be completely deleted. The member can't own content or groups when being removed.
Also, ideally, the ERIS access (GeoNET identity, etc.) would remain intact for a user leaving the organization and reverting to a personal account...
Mike MinamiSince it's been a few years, I just wanted to check to see if anything has changed related to the possibility of removing someone from an AGOL org without deleting their account (preferably, moving to personal account),,,?
Dan
If this is a 30 day trial and you don't end up subscribing, the account will automatically be deleted. Alternatively, you can contact Esri technical support, provide your username and subscription ID and your account can be deleted.
Contact Tech Support
Mike
Hi I have problem to delete my arcgis online account. I can't see anything "delete account" or something thing like that. How can I solve my problem?
Thanks
Currently, there are no plans for increased automation of content transfer and user removal. We have a general solution that works (although laborious) across different types of organizations. Admittedly, an organization representing a school has slightly different requirements because students come and go in groups, whereas people leave in smaller numbers in other types of organizations; thus, the transfer of user content is more easily managed.
However, I can see the merits of having some bulk ownership transfer of items and groups to a single user. I don't think we'll ever allow a choice to just delete all content in bulk. We are intentionally conservative in this respect because we don't want admins accidentally deleting content without reviewing it, because there is no undo.
I will write up bulk transferring of ownership as an enhancement. However, as we have a working solution, there's no guarantee this will be implemented.
David,
I just spent a little time doing this. It is a bit tedious--but intuitive. Only decision is whether to simply delete the student content, or to transfer their content and ownership of their groups over to a faculty member.
If just deleting, it goes quickly, but that may upset their faculty. So, I've just created a "transfer" folder for each faculty to hold student content and then assign ownership to faculty member placing it in the "transfer"folder. The Group content remains intact--so also have to transfer the group to the faculty now owning the content. Then able to delete the student account.
Mike Minami for organizational accounts with transient membership, like Educational institutions, it would be very helpful to provide an automated deprovisioning method to Administrator's (or the primary Admin). Perhaps -- simple clear all group ownership with drop down assignment to another user, and then a choice to delete all content or to transfer all content ownership to another user. And finally delete the user.
Stuart
I am having the same problem. Did you find a way to remove students without it being such a laboro
ius process.
Yes, this is the way it works. You can't be a member of an organization and also have personal content that doesn't belong to the organization. I equate this to having a work email address and a personal email address. When you leave your organization, you don't take your work email address with you. If your users have personal content, they should join your organization using a different account, or one that you create for them.Thanks,Mike
