Hi David
Yes I too have encountered this error message - and I thought it was just me being somewhat ICT incompetent ;-).
Cheers
Rob
I know this is old, but did you get a resolution? I now have a user with the same error?
I'm getting the same error message, in ArcMap 10.3 though. For the sake of people trying to search for the error message, the actual error message, including misspellings, is:
ArcGIS Sign In
An error has occured. Check you network connection and try again.
I am also having this problem. From Arc Map as well as ArcCatalog.
I am connected to the internet (I'm posting this message right now!)
After digging around I found a connections tab in Catalog that I may need to fill out. I will check with my IT people when they get in. If I resolve it, I will try to remember to post it here.
Hello Everyone,
Sometimes this issue can be caused by your trusted sites. ArcGIS Catalog will respect the WinInet Options. I suggest adding the following lines to your trusted sites:
*note: If you can, uncheck the box that states 'Require Server Verification...'
Go to Internet Options > Security > Trusted Sites and select the 'Sites Button'
Add the following URLS:
http://www.arcgis.com
http://*.arcgis.com
This will correct this issue for some customers. You can use web debugging tools, such as Fiddler, to troubleshoot these kinds of issues as well.
I hope this helps. Thank you very much-
Justin
Esri Support
Ahh, I realized you meant to do this in internet explorer, so I went and entered those settings in Internet Explorer. I relaunched Arc Map and there was no change. The error message still pops up when I click the 'log in' button in the ArcGIS Online window.
I am using ArcGIS 10.2.1.3497
Hello Eric,
Thank you for the reply. I will need more information to help you out further. Would you be able to take a web traffic capture while reproducing the issue?
Here is a link to a really good Web Debugger:
Fiddler free web debugging proxy
Please ensure you turn on https captures:
How to use Fiddler to capture HTTPS sessions and convert to a VSTS Web Test - Girish's Blog - Are you developing ON the …
Here is a small blog from Microsoft on how to use this product:
Fiddler PowerToy - Part 1: HTTP Debugging
Please save the log as a .saz and add them to the post. You can private message me them if you need as well. Thank you-
I was able to solve this by using the instructions from this thread: https://community.esri.com/message/130466#436122
1. In Internet Explorer, click the Tools toolbar button and choose the menu command Internet Options.2. Click the Advanced tab.3. Click the Reset button.4. The Reset Internet Explorer Settings dialog box appears. 5. Click the Reset button in the Reset Internet Explorer Settings dialog box.6. Click the Close button.7. Click the OK button and then:8. Close all open Internet Explorer windows to restart Internet Explorer.9. Restart the pc
9. Restart the pc
I'm not sure why changing settings in Internet Explorer, which I almost never use, affects ArcMap. I'm also not sure if this fix is permanent - it worked today though. If you do use IE and you've customized your settings, you may lose all your customizations.
Adding https://www.arcgis.com and https://*.arcgis.com to the internet option's trusted sites worked.
I got the same error - this worked for me:
