Is there a tool (in ArcMap) to extract data from a map or feature service I am accessing?
Thank you,
Hani
Not specifically no. If you can filter your search so that you want fewer records than the server's record limit, you can query the map service. Open up the map service in a browser. Navigate to the service you want and there should be a QUERY link at the bottom. Fill out the form and request the results in json (if you want everything you can always try WHERE 1=1). Copy paste them into a text file and you can use a JSON to features tool that will build the polygons with attributes for you. It can be time consuming but it is possible.
For image service if the download capability is checked (not default) you can use right click, Data, Download selected rasters.
You must select some rasters before the option is enabled.
Hi Hani,
Take a look at the following tool:
http://epro.maps.arcgis.com/home/item.html?id=16e5cc64178941839eca62837f168ec9
Thanks for posting this tool Jake - REALLY HELPFUL. I was trying to use ArcMap to export 120k+ features from an AGS feature service that one of our partnering agencies had set up....I kept getting a "client timeout/server not responding error". I noticed that when I selected a small number of features the AGS feature service export would complete successfully. I know that on our own AGS feature services that the max number of records returned by server is set at 1000 (default presumably). And from looking at the code you have provided, this tool appears to dice up the download/extract in chunks of 1000 records by ObjectID. Am I connecting the dots correctly here? - That the 1000 record limit is expected per this client/server process and being accounted for in your code? Or, let me know otherwise....
Thanks again!
-Nick
Yes, that is correct. The script appends 1000 features at a time.
Jake Skinner,
I was going to try using your tools. It is a secure service so I entered my credentials. The script acts as if it cannot generate a token. One thing I notice is that when I type in my password and move on to the next box the number of characters change in the password box, I'm hoping it is not defaulting to another password that I cannot see.
Executing: DownloadService false true http://<serviceurl>/countymap/rest/services/Clip_Ship/CL_ParcelData/FeatureServer/8 true false JWhite ***** "Database Connections\Connection to GIS-SERVER.sde\acgis.DBO.Address\acgis.DBO.AddressPoints" false # Start Time: Thu Sep 24 09:33:31 2015 Running script DownloadService... Generating Token URL is incorrect. Or, Service is secure, please enter username and password. Failed script DownloadService... Traceback (most recent call last): File "C:\Users\Josh White\AppData\Roaming\ESRI\Desktop10.3\ArcToolbox\My Toolboxes\Download Service with Attachments.py", line 53, in <module> iteration = int(data['objectIds'][-1]) KeyError: 'objectIds' Failed to execute (DownloadService).
Hey Josh,
I believe I fixed the issue, and updated the tool:
http://countysandbox.maps.arcgis.com/home/item.html?id=2b1f198be4ea44288418fd39f1d0aff0
Re-download the tool and let me know if you run into the same issue.
Thanks.
It comes back with a bit different error this time:
File "C:\Users\Josh White\AppData\Roaming\ESRI\Desktop10.3\ArcToolbox\My Toolboxes\Download Service with Attachments.py", line 46, in <module>
params = {'where': '1=1', 'returnIdsOnly': 'true', 'token': token, 'f': 'json'}
NameError: name 'token' is not defined
I have another question, is the intent to do one layer at a time? If that is the case, I would need the ID number for the layer, is that correct? I've tried it both ways and the error is the same for both methods so it is catching on something else first. It appears it is still "catching" because of the secure service. I'm afraid I don't know enough python to know what I am looking at.
Thanks Jake Skinner for the python script. This is awesome!
Just an FYI for all - in ArcGIS Pro, you can use geoprocessing tools such as 'Feature Class to Feature Class' to export data from a layer off a map service. And you can download all data not just first 1,000 or whatever is MaxRecordCount is set to (as long as the server is not an older version).
Steps
I am trying to fetch data from a map server that I do not manage and I am receiving the following error:
Proxy server got bad address from remote server (verify the server is running). (status code 504).
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
