I have been using ArcGIS for a few years now but have only started using Python scripting for ArcGIS for a month or so. I am trying to create a script and i am having a hard time trying to get it to work (Error after Error).In ArcGIS i have used SELECT BY LOCATION and exported the selected records as a dBASE table into my file. I have been able to create the Python script to help me do this and also to convert it into an Excel file.import arcpyfc = 'Z:\\GIS TEST\\Codes\\Codes\\K.Dun\\Export_Output_2.dbf'CSVFile = 'Z:\\Excel.csv'fields = [f.name for f in arcpy.ListFields(fc)]for i,f in enumerate(fields): if f == 'Shape' or f == 'Shape_Length' or f == 'OBJECTID': del fieldswith open(CSVFile, 'w') as f: f.write(','.join(fields)+'\n') #csv headers with arcpy.da.SearchCursor(fc, fields) as cursor: for row in cursor: f.write(','.join([str(r) for r in row])+'\n')This is fine but it requires me to manually use SELECT BY LOCATION and export the dBASE (.dbf) file before i run the script. Is there any script i can write that will allow to SEARCH BY LOCATION then export the selected records into an Excel file all in one go.I created a SEARCH BY LOCATION script but don't know how i would join them.import arcpyarcpy.env.workspace = "Z:\GIS TEST\Select_by_Location"arcpy.MakeFeatureLayer_management('Bld_Locations.shp', 'Bld_Locations_lyr') arcpy.SelectLayerByLocation_management('Bld_Locations_lyr', "WITHIN_A_DISTANCE", 'Breakout_Location.shp', "2000 Meters", "NEW_SELECTION")Anyone have any ideas?Please remember my Python knowledge is very limited.
import arcpy arcpy.env.workspace = "Z:\GIS TEST\Select_by_Location" arcpy.MakeFeatureLayer_management('Bld_Locations.shp', 'Bld_Locations_lyr') arcpy.SelectLayerByLocation_management('Bld_Locations_lyr', "WITHIN_A_DISTANCE", 'Breakout_Location.shp', "2000 Meters", "NEW_SELECTION") fc = 'Bld_Locations_lyr' CSVFile = 'Z:\\Excel.csv' fields = [f.name for f in arcpy.ListFields(fc)] for i,f in enumerate(fields): if f == 'Shape' or f == 'Shape_Length' or f == 'OBJECTID': del fields with open(CSVFile, 'w') as f: f.write(','.join(fields)+'\n') #csv headers with arcpy.da.SearchCursor(fc, fields) as cursor: for row in cursor: f.write(','.join([str(r) for r in row])+'\n')
