Hi Jochen Manegold
Can you elaborate on how you would use the Calculate Value tool to match a file_name to a mask_name? I have raster that are named something like ID_distance and bufffers that are also named ID_distance and I need to run zonal statistics for each raster (about 1300 rasters) in each corresponding buffer. Any ideas?
Thanks
I met the same question.Here is my solution:
You could put only one iterate function in Model , but you could get .shp(s) form different folders.
"P" means set the address as a Model Parameter.
In my case :
First, create three parameter as the folder address.
Second, execute the Iterate and functions.
Finally, set the out put folder. e.g. %Output_Folder%\%Name%.shp
Hi 宇恩 楊
Can you elaborate more about how you managed to use two different folders as an inputs to the model ?
Thank you
宇恩 楊
I also have this challenge and am really struggling to find a solution. Can you please elaborate on this?
