Hi
Installed fresh ArcGIS Explorer Desktop 3400 in Windows. I have added layer with mappable data from external ArcGIS. I can see the objects on Map. But cannot seem to find a way to click on an object and see underlying properties. Such as "i" in ArcGIS ArcMap.
Similar behaviour even in ArcGISonline.
https://www.arcgis.com/home/webmap/viewer.html?useExisting=1
I can see the objects on Map, but do not see a way to "identify" in order to see properties.
Can you please check and advise?
Thank you
