function loadSearch() { var bqTask = new esri.tasks.QueryTask(mapURL + "/" + bldgLayerId); var bldgQuery = new esri.tasks.Query(); bldgQuery.returnGeometry = false; bldgQuery.outFields = ["OBJECTID", "NAME", "BLDCODE", "KEYWORDS", "TYPE", "STATUS", "LABEL", "CAMPUS_ID"]; bldgQuery.where = "CAMPUS_ID = 'MAIN' AND STATUS <> 'Restricted'"; bqTask.execute(bldgQuery); dojo.connect(bqTask, "onComplete", function (nResults) { var bldgItems = dojo.map(nResults.features, function (item) { return item.attributes; }); log(bldgItems.length); var data = { 'identifier': "OBJECTID", 'label': "NAME", 'items': bldgItems }; bldgStore = new dojo.data.ItemFileReadStore({ data: data }); var searchDD = dijit.byId("bldgDD"); searchDD.set("store", bldgStore); searchDD.searchAttr = "NAME"; searchDD.fetchProperties = { sort: [{ attribute: 'NAME'}] }; dojo.connect(searchDD , "onChange", function (queryID) { }); } function queryID(bldgid) { var qidTask = new esri.tasks.QueryTask(mapURL + "/" + bldgLayerId); var queryid = new esri.tasks.Query(); var selectedBldg = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NULL, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([204, 0, 0]), 2)); queryid.returnGeometry = true; queryid.outFields = ["OBJECTID", "NAME", "BLDCODE", "KEYWORDS", "TYPE", "STATUS", "LABEL"]; queryid.where = "OBJECTID = " + bldgid; //When the query completes, select the building dojo.connect(qidTask, "onComplete", function (featureSet) { if (featureSet.features[0]) { if (map.graphics) { map.graphics.clear(); } var graphic = featureSet.features[0]; var bldgnm = graphic.attributes["NAME"]; var blcode = graphic.attributes["OBJECTID"]; graphic.setSymbol(selectedBldg); //Add graphic to the map graphics layer. map.graphics.add(graphic); var selExtent = esri.graphicsExtent(map.graphics.graphics).expand(2); map.setExtent(selExtent); } }); qidTask.execute(queryid); }
require(["dojo/ready", "dojo/dom", "dojo/query", "esri/map", "esri/toolbars/navigation", "esri/tasks/query", "esri/dijit/Scalebar", "dijit/dijit", "dijit/layout/ContentPane", "dijit/layout/TabContainer", "dijit/Toolbar", "dijit/form/Button", "dijit/form/ToggleButton", "dijit/form/FilteringSelect", "dijit/TitlePane", "dojo/store/Memory", "dojo/data/ObjectStore" ]); var basemap, navToolbar, map, bldgStore, selectedBldg, visible = []; // var mapURL = "http://.../rest/services/MU_Base/MapServer"; var bldgLayerId = 58; var baseLayers = [58,59,61,62,63]; function Init() { map = new esri.Map("mapDiv", { logo: false }); var imageParameters = new esri.layers.ImageParameters(); imageParameters.format = "PNG24"; //set the image type to PNG24, note default is PNG8. basemap = new esri.layers.ArcGISDynamicMapServiceLayer(mapURL, { "imageParameters": imageParameters }); map.addLayer(basemap); //** Add the navigation toolbar navToolbar = new esri.toolbars.Navigation(map); selectedBldg = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NULL, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([204, 0, 0]), 2)); //** CONNECT MAP FUNCTIONS dojo.connect(map, "onLoad", loadBuildingStore); //dojo.connect(map, "onExtentChange", extentHistoryChangeHandler); //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in var resizeTimer; dojo.connect(map, 'onLoad', function (theMap) { var scalebar = new esri.dijit.Scalebar({ map: map, scalebarUnit: 'english' }); dojo.connect(dojo.byId("mapPanel"), 'resize', function () { map.resize(); }); visible = basemap.visibleLayers; }); } dojo.ready(Init); function loadBuildingStore() { var bqTask = new esri.tasks.QueryTask(mapURL + "/" + bldgLayerId); var bldgQuery = new esri.tasks.Query(); bldgQuery.returnGeometry = false; bldgQuery.outFields = ["OBJECTID", "NAME", "BLDCODE", "KEYWORDS", "TYPE", "STATUS", "ADDRESS"]; bldgQuery.where = "CAMPUS_ID = 'MAIN' AND STATUS <> 'RESTRICTED'"; bqTask.execute(bldgQuery); dojo.connect(bqTask, "onComplete", function (nResults) { var bldgItems = dojo.map(nResults.features, function (item) { //ATTEMPT TO SEE IF PROBLEM LIES IN INTEGER VALUE FOR IDENTIFIER IN DATASTORE? NO DIFFERENCE var idStr = item.attributes.OBJECTID.toString(); item.attributes.OBJECTID = idStr; return item.attributes; }); var data = { 'identifier': "OBJECTID", 'items': bldgItems }; var objStore = new dojo.store.Memory({ data: data, idProperty: 'OBJECTID' }); var select = new dijit.form.FilteringSelect({ id: "bldgDD", style: "width: 300px;", placeHolder: "Select a building or start typing", store: dojo.data.ObjectStore({ objectStore: objStore }), required: false, labelAttr: 'NAME', fetchProperties: { sort: [{ attribute: 'NAME'}] }, // onChange: queryID onChange: function (val) { log(val); //queryID(val); } }, "bldgDD"); }); }
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Dojo Dropdown Demo</title> <link rel="stylesheet" href="https://community.esri.com//serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css"> <!-- ArcGIS API for JavaScript --> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0compact"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("esri.tasks.Query"); dojo.require("dijit.form.FilteringSelect"); dojo.require("dojo.data.ItemFileReadStore"); dojo.addOnLoad(init); var map,queryTask; function init() { queryTask = new esri.tasks.QueryTask("http://armstrong.uww.edu/ArcGIS/rest/services/NewCampus/MapServer/27"); map = new esri.Map("map"); dojo.connect(map, "onLoad", function() { //populate dropdown executeQuery(); }); // Add the campus basemap var campusMap = new esri.layers.ArcGISTiledMapServiceLayer('http://armstrong.uww.edu/ArcGIS/rest/services/NewCampus/MapServer'); map.addLayer(campusMap); } function executeQuery() { //execute the query task then populate the dropdown menu with list of building names var query = new esri.tasks.Query(); query.returnGeometry = true; query.outFields = ["BldgName","FID"]; query.where = "1=1"; queryTask.execute(query,populateMenu); } function populateMenu(featureSet){ var items = dojo.map(featureSet.features, function (item) { return { name: item.attributes.BldgName, id:item.attributes.FID }; }); var data = { identifier:"id", items:items }; var objStore = new dojo.data.ItemFileReadStore({data:data}); var filteringSelect = new dijit.form.FilteringSelect({ style:'width:300px;', placeHolder:'Select a building or start typing', store:objStore, required:false, labelAttr:'name', fetchProperties:{sort:[{attribute:'name'}]}, onChange:function(val){ if(val){ var selectQuery = new esri.tasks.Query(); selectQuery.returnGeometry = true; selectQuery.objectIds = [val]; queryTask.execute(selectQuery,function(featureSet){ map.graphics.clear(); //clear any existing map graphics //get the first feature and add to map if(featureSet.features.length > 0){ var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2),new dojo.Color([255,255,0,0.25])); var feature = featureSet.features[0]; var graphic = new esri.Graphic(feature.geometry,symbol); map.graphics.add(graphic); } }); } } },'bldgSelect'); } </script> </head> <body class='claro' style="font-family: Arial Unicode MS,Arial,sans-serif;"> <input id='bldgSelect'/> <div id="wrapper" style="position: relative; width: 700px; height: 500px; border:1px solid #000;"> <!-- Map canvas --> <div id="map" style="position: absolute; width: 700px; height: 500px; z-index: 1;"></div> </div> </body> </html> �??
Thanks for directing me to that sample, that's what I've been hunting for. I wish they hadn't buried it there but at least it's a start.I'm disappointed that I will apparently have to significantly rewrite and restructure pretty much all of my code on all of my sites with the new release. The differences are substantial.
Unfortunately, lots of links like this are now broken.
