Background:
I've used the Near Analysis tool which has added the following fields:
- NEAR_X (X Coordinate)
- NEAR_Y (Y Coordinate)
I'd like to use the following fields from the output of using the Near Analysis tool to generate a Structured NumPy Array:
- HydroID (Unique ID: Long Integer)
I've read through the ESRI online help documentation on:
, and I'm unable to figure out how to generate a Structured NumPy Array that I can use as input to NumPyArrayToFeatureClass. The Structured NumPy Array format that is required as input to NumPyArrayToFeatureClass is:
array = numpy.array([(1, (471316.3835861763, 5000448.782036674)),
(2, (470402.49348005146, 5000049.216449278))],
numpy.dtype([('idfield',numpy.int32),('XY', '<f8', 2)]))From what I gathered the coordinates are stored as tuples within the Structured NumPy Array. I'm still learning to code so any assistance in how to covert my data into a Structured NumPy Array that I may use as input into NumPyArrayToFeatureClass will be appreciated.
Regards
PeterW
