When packaging the result, did you specify the option to Support ArcGIS Runtime?
Prepare a geoprocessing service for offline use | ArcGIS for Developers (Step 14)
Thanks
Mike
Hi Mike,
I cann't find the option "Support ArcGIS Runtime". I'd checked the options in both the Geoprocessing Package and the current project, still cannot find it. Can you show me where is it?
My ArcGIS Pro Version is 2.6. The following is the UI of generating gpk with no error.
Thank you
Yanzhengmei
Note you need to use the Package Result tool Prepare a geoprocessing service for offline use(Step 11).
I'd followed the steps to share a gpkx. But cannot find the option 'Support ArcGIS Runtime', neither it's in the geoprocessing package pane, nor is in the project option pane. The problem is where to fine the option 'Support ArcGIS Runtime', can you show me?
It is an option on the Package Result tool (Package Result (Data Management)—ArcGIS Pro | Documentation ).
You mean the option "Support ArcGIS Runtime" cannot not be specified in the geoprocessing package pane, only be specified in tool?
I'd tried to use this tool but failed. I'd run the ImportLandsD tool for many times, so there are more then one results with the same name.
How to set the in_result value for PackageResult_management?
