I have a base map from ESRI showing a road in North Citrus County Florida that should end. However it does not and connects to a road that it should not connect too. The Road is N. Fauci Pt. and should end at private property. Landowner is having trespass issue due to this.
Should be like this on your openstreetmap open source map.
Landowner would appreciate a fix to this.
Vilmantas Alekna,There isn't a specific item in ArcGIS Online for reporting feedback on the Light Gray Canvas basemap, so you can just post what you notice in these forums.Thanks,Mike
If you spot errors in the map, you can also report them in the following feedback maps.Imagery Map FeedbackStreet Map FeedbackTopographic Map Feedback. Cheers,Andrew
