What was your estimated positional accuracy? I would assume you did not have a RTK fixed solution at the time so that is why the coordinate values varied.
If receiving RTK corrections and my estimated positional error is at 1 cm then my coordinate values are all well within specification. You should compare your X, Y, Z values.
