this is in C#override Tool Cursor method andreturn Cursors.Cross.Handle.ToInt32();
<Tool id="Microsoft_ArcMapAddin1_Jeffry_Class" class="Jeffry_Class" message="This is the description" caption="Jeffry" tip="Cursor Tooltip" category="AddInControls" image="Images\Jeffry_Class.png" cursor="Images\JeffryCustomCursor.cur">
'OnMouse down Protected Overrides Sub OnMouseDown(ByVal arg As ESRI.ArcGIS.Desktop.AddIns.Tool.MouseEventArgs) MyBase.OnMouseDown(arg) 'Code here on Mouse down End Sub
'for Cursor - create the cursor m_Cursor = New System.Windows.Forms.Cursor(Me.GetType.Assembly.GetManifestResourceStream("FocusToolsToolbar.CrosshairCursor.cur")) If Not m_Cursor Is Nothing Then mh_Cursor = m_Cursor.Handle End If Public ReadOnly Property cursor() As Integer Implements ESRI.ArcGIS.SystemUI.ITool.Cursor Get Return mh_Cursor.ToInt32 End Get End Property
OnActivate() System.Windows.Forms.Cursor.Current = Cursors.WaitCursor 'do stuff My.ArcMap.Application.CurrentTool = Nothing End Sub
I had much better success usingOnActivate() System.Windows.Forms.Cursor.Current = Cursors.WaitCursor 'do stuff My.ArcMap.Application.CurrentTool = Nothing End Sub
Can you elaborate on how this can be implemented? I am trying to change my tool cursor after click events, from one cursor to another, depending on the current click's function. I am currently only able to set the cursor to default Window.Forms.Cursors.
