I believe you need this infopopup widget for it to work. See attachment.Yas(h)ar
At the bottom of the SelectionWidget.xml there is an <info>widgets/InfoTemplates/InfoPopupWidget.swf</info> tag.Make sure it is set to the correct path to your .swf file (remember, it is CaSe sensitive).If that doesn't work, what does the rest of the error message say?R_
widgets/InfoPopup/InfoPopupWidget.swf
Here You are:[ATTACH=CONFIG]27926[/ATTACH][ATTACH=CONFIG]27927[/ATTACH]
Does anyone have explanations of the SelectionWidget.xml options available?
Does anyone have a compiled version that works with 3.6 or 3.7?
Thanks
Spero but i don't have
Inviato da iPhone
Il giorno 05/mar/2015, alle ore 15:16, Kummer Laszlo <geonet@esri.com> ha scritto:Selection Widget Updated Versionreply from Kummer Laszlo in ArcGIS Viewer for Flex - View the full discussionDoes anyone have a compiled version that works with 3.6 or 3.7? ThanksReply to this message by replying to this email, or go to the message on GeoNetStart a new discussion in ArcGIS Viewer for Flex by email or at GeoNetFollowing Selection Widget Updated Version in these streams: InboxThis email was sent by GeoNet because you are a registered user.You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
Hi. Are you referring to this widget?
Yes.
Il giorno 05/mar/2015, alle ore 16:41, Lefteris Koumis <geonet@esri.com> ha scritto:Selection Widget Updated Versionreply from Lefteris Koumis in ArcGIS Viewer for Flex - View the full discussionHi. Are you referring to this widget?https://community.esri.com/servlet/JiveServlet/downloadImage/2-463158-68645/pastedImage_0.pngReply to this message by replying to this email, or go to the message on GeoNetStart a new discussion in ArcGIS Viewer for Flex by email or at GeoNetFollowing Selection Widget Updated Version in these streams: InboxThis email was sent by GeoNet because you are a registered user.You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
Attached is compiled for 3.6.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
