Has anyone worked out how to export a dataset to Shapefile from within ArcGIS Pro? The Share tab does not seem to have the shapefile option....
Thanks for your time.
I believe the task you're looking to perform is under the "Data" tab. There is a button called "Export Features" which allows you to export to a shapefile. See attachment.
Hi Ben,
I believe the tool you need is a toolbox tool found in the analysis ribbon:
Hope this helps
Alex
I can't seem to find the option where I can export to a shapefile. Am I missing a step? It only allows me to export as a feature class. The tool description says that I should be able to export as both.
Thank you,
julius
Hi Julius,
It should automatically export to a shapefile because your export location is a standard windows folder.
You would need to export it directly into a geodatabase to get a feature class.
Ahhh got it! I had a problem with the folder I was trying to save in.
Thank you Alana! It's gonna take a while to get used to ArcGIS Pro...
I find it a little weird that the tool window doesn't differentiate between Feature Class or Shapefile until it automatically appends the file path if it's in a standard windows folder. But this method works for me too.
