Is there a way to add image on esri map using javascript api 4.0 (or 3.16)?
Pavel,
In 3.16 look at the MapImageLayer class:
MapImageLayer | API Reference | ArcGIS API for JavaScript
Great, thanks! Sorry that I missed that in the documentation.
A sample code is below, the images placed on application folder on this sample.
dojo.require("esri.map");
dojo.require("esri.layers.MapImageLayer");
function init() {
//var initialExtent = new esri.geometry.Extent({"xmin":4488509,"ymin":5477146,"xmax":4491257,"ymax":5479894,"spatialReference":{"wkid":31494}});
var initialExtent = new esri.geometry.Extent({"xmin":23.66,"ymin":37.84,"xmax":23.84,"ymax":38,"spatialReference":{"wkid":4326}});
var map = new esri.Map("map",{extent:initialExtent});
//var imageParameters = new esri.layers.ImageParameters();
//imageParameters.format = "jpeg"; //set the image type to PNG24, note default is PNG8.
//Takes a URL to a non cached map service.
//var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://83.235.175.160:2121/ArcGIS/rest/services/iMAGEsERVER/MapServer", {"opacity":0.1 , "imageParameters":imageParameters});
//map.addLayer(dynamicMapServiceLayer);
//var mi = new esri.layers.MapImage({
// 'extent': { 'xmin': 4488510.42536545, 'ymin': 5477147.18036545, 'xmax': 4491256.57463455, 'ymax': 5479893.32963455, 'spatialReference': { 'wkid': 31494 }},
// 'href': '_ags_map91b8e8b3704d49bfac34ee9b14674ecf.png'
var a1 = new esri.layers.MapImage({
'extent': { 'xmin': 23.758746844, 'ymin': 37.945549845, 'xmax': 23.761399943, 'ymax': 37.947220227, 'spatialReference': { 'wkid': 4326 }},
'href': 'A1.jpg'
var a2 = new esri.layers.MapImage({
'extent': { 'xmin': 23.761392805, 'ymin': 37.945545086, 'xmax': 23.764045904, 'ymax': 37.947215468, 'spatialReference': { 'wkid': 4326 }},
'href': 'A2.jpg'
var a3 = new esri.layers.MapImage({
'extent': { 'xmin': 23.764036386, 'ymin': 37.945545086, 'xmax': 23.766689485, 'ymax': 37.947215468, 'spatialReference': { 'wkid': 4326 }},
'href': 'A3.jpg'
var b1 = new esri.layers.MapImage({
'extent': { 'xmin': 23.758753982, 'ymin': 37.947194053, 'xmax': 23.761407081, 'ymax': 37.948864434, 'spatialReference': { 'wkid': 4326 }},
'href': 'B1.jpg'
var b2 = new esri.layers.MapImage({
'extent': { 'xmin': 23.761397564, 'ymin': 37.947191673, 'xmax': 23.764050663, 'ymax': 37.948862055, 'spatialReference': { 'wkid': 4326 }},
'href': 'B2.jpg'
var b3 = new esri.layers.MapImage({
'extent': { 'xmin': 23.764038765, 'ymin': 37.947189294, 'xmax': 23.766691864, 'ymax': 37.948859675, 'spatialReference': { 'wkid': 4326 }},
'href': 'B3.jpg'
var mil = new esri.layers.MapImageLayer({
'id': 'usgs_screen_overlay'
mil.addImage(a1);
mil.addImage(a2);
mil.addImage(a3);
mil.addImage(b1);
mil.addImage(b2);
mil.addImage(b3);
map.addLayer(mil);
dojo.addOnLoad(init);
Thanks for the sample code!
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
