I have a multipatch layer, which I created form some 3d studio files. All Z units are feet, andf the XY coordinate system is State Plane Feet. So far so good.
Adding this as a layer to a 3D scene in ArcfGIS Pro 2.01, the Source Coordinate system lists the spatial reference correctly: Feet. In the same Layer>Source view, the "Data Source Vertical Units" are listed as Meters.
To get the layer to look right, I can over-ride this in the Layer Elevation Properties. Which is what I normally do.. My problem nos is that the layer can't be edited unless the Elevation Units and the Data Source Vertical units are the same.
So my question is: is it possible for a user to change or fix the Data Source Vertical Units?
Thanks
--pbc
