Snažím se publikovat gas utility network podle pokynů Začínáme s Gas Utility Network ConfigurationZačínáme | ArcGIS for Gas<\/A> <\/P><\/P>Nicméně jsem obdržel chybovou zprávu, jak je uvedeno níže.<\/P>Mé nasazení ArcGIS Enterprise:<\/P> - Portal for ArcGIS 10.6<\/P> - ArcGIS Server site 10.6 + Utility Network extension <\/P><\/P><\/P><\/P>Nějaké nápady, kde by mohl být problém?<\/P><\/P>Děkuji,<\/P>Hung Truong<\/P>AltaGas Utilities Inc.<\/P><\/BODY><\/HTML>
<\/P>
Děkuji,<\/P>
Hung Truong<\/P>
Hi Vinay,
Have you resolved your issue(s)?
What I did to fix my issue was to rolled back ArcGIS Pro 2.1.
You cannot publish UN to Portal 10.6 using ArcGIS Pro 2.2. Or just wait for a few weeks until ArcGIS Enterprise 10.6.1 release.
I hope this helps.
Hung Truong
Hung,
Where did you find the information out about ArcGIS Pro 2.2 isn't compatible with Enterprise 10.6 for the UN?
I'm having the same issue and my Esri partner doesn't know this either.
Thanks
I am also facing the same issue, The error in server log is:
Level Time Message SourceSEVERE Jul 6, 2018, 10:14:36 AM Error executing tool. PublishServiceDefinition Job ID: jd4d2f7ef93184b018aa31289db319c0c : ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details. ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition). Failed. Failed to execute (Publish Service Definition). System/PublishingTools.GPServerSEVERE Jul 6, 2018, 10:14:36 AM Delegate job failed. System/PublishingTools.GPServerSEVERE Jul 6, 2018, 10:14:34 AM Error executing tool. PublishServiceDefinition Job ID: jbd0147f18c3e43c783f0f511dbc0c4b7 : ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details. ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition). System/PublishingToolsEx.GPServerSEVERE Jul 6, 2018, 10:14:34 AM Failed to create the service.: Updating the server connection string for layer Gas Device failed. Attempted connection string was ENCRYPTED_PASSWORD=00022e68347042307051332f70792f41674672347666676f2f7372375a732f4133555257764171447067324c5335343d2a00;SERVER=localhost;INSTANCE="DSID=e12499c9-d26a-4b26-bc68-5ca4794dc002";DBCLIENT=sqlserver;DB_CONNECTION_PROPERTIES=localhost;DATABASE=NPU;USER=NPU9;AUTHENTICATION_MODE=DBMS;BRANCH=sde.DEFAULT. Table name is NPU.NPU9.PipelineDevice. Please verify the data exists on the server. System/PublishingToolsEx.GPServerSEVERE Jul 6, 2018, 10:14:34 AM DoAfterSDExtraction failed. System/PublishingToolsEx.GPServerSEVERE Jul 6, 2018, 10:14:34 AM SwizzleService failed. System/PublishingToolsEx.GPServer
Any help would be appreciated
Vinay
Can you please log a tech support incident for this?
