I need to find a way to create a line at the location the data frame cuts off a map. Any ideas?
I have not used this tool, but it might do the trick. The result is a polygon feature class of the map extent. In your case, you can then convert it to a line with the Feature to Line tool in ArcToolbox (and then delete any unneeded linework).
Map Extent to Polygon (ArcMap add-in, Jakub Sisak)
http://www.arcgis.com/home/item.html?id=a9b032f739254ebeb6221c9294ebc886
Chris Donohue, GISP
I just downloaded the tool and ran it. This was exactly what I was looking for thank you!!!
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
