In my below script, i am trying to export features which are having null or 0 values for some particular fields(listed in fieldList) from the GDB.I found that the problem is with update cursor.I tring for long time and still not able to solve. Could someone help me how to do it? import arcpy,os arcpy.env.overwriteOutput = True targetGdb = arcpy.GetParameterAsText(0) workFolder = os.path.dirname(targetGdb) outFolder = workFolder + os.sep + "CheckforErrors" if not arcpy.Exists(outFolder): arcpy.CreateFolder_management(workFolder, "CheckforErrors") attrErrPt = "AttributionError_Points" attrErrL = "AttributionError_Lines" attrErrP = "AttributionError_Polygons" if not arcpy.Exists(attrErrPt): arcpy.CreateFeatureclass_management(outFolder, attrErrPt, "POINT") if not arcpy.Exists(attrErrL): arcpy.CreateFeatureclass_management(outFolder, attrErrL, "POLYLINE") if not arcpy.Exists(attrErrP): arcpy.CreateFeatureclass_management(outFolder, attrErrP, "POLYGON") outErrPt = outFolder + os.sep + "AttributionError_Points" outErrL = outFolder + os.sep + "AttributionError_Lines" outErrP = outFolder + os.sep + "AttributionError_Polygons" fieldList = ['feattype','idarpt','name','source','ZV7','featsource','imagery','status','idthr','Z5M', 'idstd','tdze','tdzslope','brngtrue','brngmag','rwyslope','tora','toda','asda','lda','vasis', 'cat','thrtype','pntsttyp','marking','lighting','radius','height','material','idp','idrwy','idlin', 'color','style','direc','linsttyp','catstop','gsurftyp','idapron','idbase','ident','surftype','frq', 'station','idhot','jetway','surftype','width','length','idrwi','featbase','bridge','plysttyp'] arcpy.env.workspace = targetGdb datasetList = arcpy.ListDatasets('','feature') for dataset in datasetList: fcs = arcpy.ListFeatureClasses('','', dataset) for fc in fcs: desc = arcpy.Describe(fc) fcType = desc.ShapeType arcpy.AddMessage(fc) arcpy.AddMessage(fcType) if fcType == "Point": fields = arcpy.ListFields(fc) for field in fields: fname = field.name arcpy.AddMessage(field.name) if field.name in fieldList: rows = arcpy.SearchCursor(fc) newRows = arcpy.InsertCursor(outErrPt) row = rows.next() while row: rVal = row.getValue(fname) if rVal == None: newRo = newRows.newRow() newRo.shape = row.shape newRows.insertRow(newRo) row = rows.next() del row, rows, newRows elif fcType == "Polyline": fields = arcpy.ListFields(fc) newRows2 = arcpy.InsertCursor(outErrL) for field in fields: fname = field.name arcpy.AddMessage(field.name) if field.name in fieldList: rows = arcpy.SearchCursor(fc) row = rows.next() while row: rVal = row.getValue(fname) if rVal == None: newRow2 = newRows2.newRow() newRow2.shape = row.shape newRows2.insertRow(newRow2) row = rows.next() del row, rows elif fcType == "Polygon": fields = arcpy.ListFields(fc) newRows3 = arcpy.InsertCursor(outErrP) for field in fields: fname = field.name arcpy.AddMessage(field.name) if field.name in fieldList: rows = arcpy.SearchCursor(fc) row = rows.next() while row: rVal = row.getValue(fname) if rVal == None: newRow3 = newRows3.newRow() newRow3.shape = row.shape newRows3.insertRow(newRow3) row = rows.next() del row, rows
