PS: missed your second post about DateChoose controls, this is something that you would have to program your self as Roberts widget is set up to use input fields, but it is a good place to start
Christopher, One of my 2012 Dev Summit presentations included code and a widget for crime mapping exactly what you are talking about. It is not a mod for the eSearch it is a completely new widget, but you could glean all the basics from it. The biggest thing is SQL date ranges are a nightmare but setting a time extent works beautifully.http://gis.calhouncounty.org/devsummit2012/devsumit2012.zip
Julie,I was using the 2.5 Flex Viewer and everything I added was to the uncompiled version of Robert's widget.I have not even looked at the 3.1 version, but that is mainly because I am moving away from Flex and doing Javascript now.The changes from 2.5 to 3.1 are quite substantial, and with my time no longer devoted to Flex I have no idea when I will get around to configuring the widget to the 3.x version.Chris B.
