i = range(20) cols = 4 f = open('D:\\tmp.csv', 'w') for r in range(len(i)/cols): f.write(';'.join([str(v) for v in i[r*cols:(r+1)*cols]]) + '\n')
import numpy as np a = [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20] a = np.array(a) a = np.reshape(a, (4,5))
[[ 1 2 3 4 5] [ 6 7 8 9 10] [11 12 13 14 15] [16 17 18 19 20]]
There are also arcpy functions to convert numpy Arrays to rasters and the other way around.http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v00000130000000
array_d=arcpy.RasterToNumPyArray(raster_d) array_v=arcpy.RasterToNumPyArray(raster_v) (height_d, width_d)=array_d.shape (height_v, width_v)=array_v.shape # create empty array to store the "D" parameter newarr = np.zeros((5,4)) for row1 in range (0,height_d): row2=row1 for col1 in range (0,width_d): col2=col1 h=array_d.item(row1,col1) v=array_v.item(row2,col2) # calculate the "D" parameter expr = h+v newarr[row1,col1] = expr # write the new array to an ascii file np.savetxt("e:/out.txt", newarr, fmt="%.2f", delimiter= " ")
