hi Larry. sadly, I'm not yet very familiar with ArcGIS products .. where do I find those 'referencedâ?? images im ArcGlobe ? * * * [ATTACH=CONFIG]12114[/ATTACH] * * * Okay, let me explain how this workflow would work in the CityEngine, what works and what does not, and what the role of metadata would play.
I have gotten an other input concerning �??ArcGIS Explorer does not support 3D display�?�.-->It does�?� Are you using ArcGIS Explorer Online (which is 2D-only), or did you miss the button on the toolbar which switches from 2D to 3D?
hi !I've posted the info on the forum, so other users can also profit from the work.try an approach like this :classification 1 : VOLUMEShttp://forums.arcgis.com/threads/51733-classification-approach-towards-(volumetric)-multiPatch-dataclassification 2 : SURFACE ORIENTATION(use a comp(f) to go from the classified volumes to each polygon)http://forums.arcgis.com/threads/51546-Calculating-shape-slopesclassification 3 : SURFACE DIMENSIONfor each single polygon, test the dimension and accordingly trigger e.g. the texturing of- flat roof surface- facade- metal box surface- ..it all looks a little complex, but once you have a good rule set, you can run this rule over any number of buildings and get good texturing completely automatted. I guess in your case this approach is VERY promising.cheers !:cool:
