<div class="homeContainer"> <div class="home" data-dojo-attach-event="ondijitclick:home" role="button" title="Default extent" data-dojo-attach-point="_homeNode"> <span>Home</span> </div> </div>
require([ "esri/map", "esri/dijit/HomeButton", "dojo/i18n!esri/nls/jsapi", "dojo/domReady!" ], function( Map, HomeButton, esriBundle ) { esriBundle.widgets.homeButton.home.title = "Custom home button text."; var map = new Map("map", { center: [-56.049, 38.485], zoom: 3, basemap: "streets" }); var home = new HomeButton({ map: map }, "HomeButton"); home.startup(); });
var djtHomeButton = new HomeButton({ map: map }, "HomeButton"); djtHomeButton._homeNode.title = "This is the new title"; djtHomeButton.startup();
