<layer> <definitionexpression></definitionexpression> <enableexport>true</enableexport> <name>GPS Camera</name> <url>http://gistest.railinfra.local/ArcGIS/rest/services/GPSCamera_Data/MapServer/0</url> <expressions> <expression alias="Objecttype" textsearchlabel="Zoek op Objecttype [ Voorbeeld: ES-Las ]">upper(Memo_Value_1) LIKE upper('%[value]') OR upper(Memo_Value_1) LIKE upper('[value]%') OR upper(Memo_Value_1) = upper('[value]')</expression> <expression alias="Locatie" textsearchlabel="Zoek op Locatie [ Voorbeeld: 001-RC ]">upper(Memo_Value_2) LIKE upper('%[value]') OR upper(Memo_Value_2) LIKE upper('[value]%') OR upper(Memo_Value_2) = upper('[value]')</expression> </expressions> <graphicalsearchlabel>Gebruik onderstaande tools om foto's te selecteren</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>Memo_Value_1</titlefield> <fields all="false"> <field name="Memo_Value_1" alias="Objecttype" gridfield="true"/> <field name="Camera_DateTimeOrginal" alias="Datum" gridfield="true"/> <field name="Memo_Value_2" alias="Locatie" gridfield="true" gridfieldonly="true"/> <field name="Memo_Name_3" alias="Vraag 3" gridfield="true" gridfieldonly="true"/> <field name="Memo_Value_3" alias="Antwoord 3" gridfield="true" gridfieldonly="true"/> <field name="Memo_Name_4" alias="Vraag 4" gridfield="true" gridfieldonly="true"/> <field name="Memo_Value_4" alias="Antwoord 4" gridfield="true" gridfieldonly="true"/> <field name="Memo_Name_5" alias="Vraag 5" gridfield="true" gridfieldonly="true"/> <field name="Memo_Value_5" alias="Antwoord 5" gridfield="true" gridfieldonly="true"/> <field name="Memo_Name_6" alias="Vraag 6" gridfield="true" gridfieldonly="true"/> <field name="Memo_Value_6" alias="Antwoord 6" gridfield="true" gridfieldonly="true"/> <field name="Memo_Name_7" alias="Vraag 7" gridfield="true" gridfieldonly="true"/> <field name="Memo_Value_7" alias="Antwoord 7" gridfield="true" gridfieldonly="true"/> <field name="Memo_Name_8" alias="Vraag 8" gridfield="true" gridfieldonly="true"/> <field name="Memo_Value_8" alias="Antwoord 8" gridfield="true" gridfieldonly="true"/> <field name="Memo_Name_9" alias="Vraag 9" gridfield="true" gridfieldonly="true"/> <field name="Memo_Value_9" alias="Antwoord 9" gridfield="true" gridfieldonly="true"/> <field name="Memo_Name_10" alias="Vraag 10" gridfield="true" gridfieldonly="true"/> <field name="Memo_Value_10" alias="Antwoord 10" gridfield="true" gridfieldonly="true"/> <field name="Opmerking" gridfield="true" gridfieldonly="true"/> <field name="Hyperlink" hyperlinkgridfield="true"/> </fields> <linkfield>Hyperlink</linkfield> <icon></icon> <zoomscale>1000</zoomscale> </layer>
ArgumentError: Error #2004: Een van de parameters is ongeldig. at flash.display::Graphics/drawRect() at com.esri.ags.layers::Layer/drawBitmap() at com.esri.ags.layers::Layer/updateDisplayList() at mx.core::UIComponent/validateDisplayList() at mx.managers::LayoutManager/validateDisplayList() at mx.managers::LayoutManager/doPhasedInstantiation() at mx.managers::LayoutManager/doPhasedInstantiationCallback()
TypeError: Error #1009: Kan geen eigenschap of methode benaderen via een verwijzing naar een object dat null is. at widgets.eSearch::SearchWidgetFloatDG/clickRow() at widgets.eSearch::SearchWidgetFloatDG/__resultsGrid_itemClick() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at mx.core::UIComponent/dispatchEvent() at mx.controls.listClasses::ListBase/mouseClickHandler()
for each (var graphic:Graphic in featureSet.features)
