Holy Jesus!!! are you reading my mind (or rather my traffic (: )? totally digging into wireshark now. Will Let you know what i find.
noticed that when using Fire Bug the 'Post Get token' to access secure map services show the user name and password as plane text. is this getting encrypted at the transport level?[ATTACH=CONFIG]25096[/ATTACH]
Indeed HTTPS. Just wanted to make sure that at the transport layer this was actually getting encrypted. Thnx for the assurance GISDev01. ESRI folks care to comment on this?
If you want to see what is going over the wire, and as a fun research opportunity if you want to know more about Network Security, go ahead and install Wireshark and watch all of the traffic going over the wire and you will find your answer. I'm actually interested in what you find because I haven't looked at that traffic yet. I will check it later tonight myself.
you seeing same stuff on your end Dev01?
