We ended up removing the pyramids and statistics and rebuilding. This fixed our issue. We used Bilinear for the pyrmaid resampling technique and LZ77 for the pyramid compression. We also made sure in the environment settings, the workspace was not set to our local "N" desktop drive.
We are having very similar problems with 10.5.1 + and what appears to be inconsistency and instability with the pyramids tool. Sometimes they are successful and other times not. Successful meaning the tool reports they are built only to get prompted the pyramids do not exist or simply not seeing anything at smaller scales. Other times we are presented with this warning and have never run into this before? "C2018_MOSAIC_BLOCK1: The display area covers too many pixels at the current display resolution. Please zoom in or build pyramids." This is coming up with clicking on the raster layer and clicking "zoom to layer".
Older software releases prior to 10.3 did not appear to have this problem with our past collections in File or SDE GDB.
I am curious what settings are you using for pyramids? Applying any compression on them?
I am having a similar issue in ArcGIS 10.5.1. I have a large raster dataset (aerial imagery 3 band - 741 GB) that is stored on our SDE environment. It has pyramids and statistics. It will only render when the symbology is set to stretched. It will not render when set to RGB composite. It won't even render with RGB composite when zoomed in. I have tried changing all of the rendering symbology settings, tried changing the Raster Layer settings under ArcMap Options, and tried changing the settings using the Raster Analysis. When I clip a small section of the raster, the clipped raster displays using RGB composite. I have an ESRI ticket in and haven't made much progress with the technician. She has suggested I copy the raster to a file geodatabase, but I don't have enough room on my computer to do that. I'd probably need a brand new computer with no programs on it which is not possible. She also suggested recreating the raster as a mosaic dataset but that is also not an option. We have several years of aerial imagery rasters all saved on our SDE environment and I have to follow the parameters put in place by the GIS administrator (which is a raster dataset - not mosaic). I'm hoping this forum can help me out since I'm not having any luck with the technician. Thanks!
Have you tried deleting statistics and pyramids? If something goes awry in these files you get weird behaviours like this. I have no experience with imagery files this size, but there may even be some limitations in these GDB file structures causing issues. If they were files you could just delete the *.rrd and *.ovr.....as it is I think you'll have to trust ArcCatalog.
You may want to try some different renderers and see if they do any better. Issues like this are really good things to take to Esri support if you can -- because that's how NIM#'s (bugs) get logged -- and fixed.What is your ArcGIS Desktop version and service pack?
