//Open MXD and get first dataframe then get the first layer from the data frame. MapDocument tempMxd = new MapDocument(); tempMxd.esri_new("E:/OutputDirectory/tempmxd.mxd"); IMap map = tempMxd.getMap(0); ILayer layer = map.getLayer(0); //Create a workspace so we can work with the data WorkspaceFactory wkspf = new RasterWorkspaceFactory(); IWorkspace wksp = wkspf.openFromFile("E:/outputDir/", 0); IRasterLayerExport3 rle = new RasterLayerExport(); IRasterLayer rl = (IRasterLayer) layer; //Tweak how we want to export (at least as far as possible) rle.setRasterLayerByRef(rl); rle.setExtent(rl.getAreaOfInterest()); rle.setForce2RGB(false); //Don't compress IRasterStorageDef rsd = new RasterStorageDef(); rsd.setCompressionType(esriRasterCompressionType.esriRasterCompressionUncompressed); rle.setStorageDefByRef(rsd); //Export. rle.export(wksp, "exportLayer.bil", "BIL"); //Note: No other file types work here either but I am willing to accept any uncompressed raster type besides BIL if it works
Dim pMxDoc As IMxDocument Dim pMap As IMap Dim pRasterLayer As IRasterLayer Dim pRaster As IRaster Dim pGeometryProc As IRasterGeometryProc pMxDoc = My.ArcMap.Application.Document pMap = pMxDoc.FocusMap pRasterLayer = pMap.Layer(0) pRaster = pRasterLayer.Raster pGeometryProc = New RasterGeometryProc pGeometryProc.Resample(rstResamplingTypes.RSP_NearestNeighbor, 7, pRaster) Dim pDataset As IDataset pDataset = pRasterLayer Dim pWS As IWorkspace pWS = pDataset.Workspace Dim str As String str = pWS.PathName killifexistsRaster("try", str) Dim RasterDataset As IRasterDataset Dim pRasBandCol As IRasterBandCollection pRasBandCol = pRaster 'pDS = pRasBandCol.SaveAs("try3", pWS, "GRID") RasterDataset = pRasBandCol.SaveAs("try", pWS, "GRID") '*********************************** Dim pRasterLy As IRasterLayer pRasterLy = New RasterLayer ' pRasterLayer.CreateFromRaster(pRaster) pRasterLy.CreateFromDataset(RasterDataset) pMap.AddLayer(pRasterLy) pMxDoc.ActiveView.Refresh() '*********************************** SaveAsWithoutBuildingPyramids(pRaster) End Sub Sub SaveAsWithoutBuildingPyramids(ByVal pRaster As IRaster) 'Or as IRasterDataset) killifexistsRaster("tryexp", "C:\temp") Dim pSaveAs2 As ISaveAs2 pSaveAs2 = pRaster Dim pStorageDef As IRasterStorageDef2 pStorageDef = New RasterStorageDef pStorageDef.PyramidLevel = 0 Dim pWs As IWorkspace pWs = SetRasterWorkspace("c:\temp") pSaveAs2.SaveAs("try_exp", pWs, "GRID") End Sub Public Function SetRasterWorkspace(ByVal sPath As String) As IRasterWorkspace Dim pWsFact As IWorkspaceFactory pWsFact = New RasterWorkspaceFactory SetRasterWorkspace = pWsFact.OpenFromFile(sPath, 0) End Function Public Function killifexistsRaster(ByVal RasterName As String, ByVal strFolder As String) '''''' Delete raster from disk Dim pRWSF As IWorkspaceFactory pRWSF = New RasterWorkspaceFactory Dim pRWS As IRasterWorkspace pRWS = pRWSF.OpenFromFile(strFolder, 0) Dim pRasterDS As IRasterDataset On Error Resume Next pRasterDS = pRWS.OpenRasterDataset(RasterName) If Not pRasterDS Is Nothing Then Dim pDS As IDataset pDS = pRasterDS If pDS.CanDelete Then pDS.Delete() End If System.IO.Directory.Delete(strFolder & "\" & RasterName, True) DeleteFolder(strFolder & "\" & RasterName) End Function Public Function DeleteFolder(ByVal strPath As String) As Boolean Dim objDir As New IO.DirectoryInfo(strPath) Try objDir.Delete(True) Return True Catch Return False End Try End Function
but how to use RasterLayerExport while keep Pixel Depth?
because I want to use RasterLayerExport to export only some area of this raster
