IdList = [] rows = arcpy.SearchCursor("INPUT_FILE") for row in rows: IdPlusOne = int(row.ID_FIELD) + int(1) IdList.append(IdPlusOne) del row, rows arcpy.MakeFeatureLayer_management("FC SELECTING FROM", "layer_lyr") i = 0 for Id in IdList: if IdList == 0: arcpy.SelectLayerByAttribute_management("layer_lyr", "NEW_SELECTION", "\"ID_FIELD\" = " + str(IdList)) i+=1 elif IdList >= 1: arcpy.SelectLayerByAttribute_management("layer_lyr", "ADD_TO_SELECTION", "\"ID_FIELD\" = " + str(IdList)) i+=1 arcpy.CopyFeatures_management("layer_lyr", "NEW_FEATURE_CLASS")
import arcpy inFile = "e:/test.shp" # create searchcursor rows = arcpy.SearchCursor(inFile) #go through rows and print the values of Fields FIELD_A and FIELD_B for row in rows: print urow.FIELD_A print urow.FIELD_B del row, rows
IdList = [] for row in rows: IdPlusOne = row.ID + 1 IdList.append(IdPlusOne) del row, rows print IdList
where = "FIELD in ('" + '\',\''.join(dataList) + "')"
listRecords(myTable, 20, "MYFIELD = 1")
def listRecords(inputValue, numberOfRecordsToList = 25, whereClause = ""): "Lists field names and values in inputValue" if gp.exists(inputValue) == 1: fieldNamesList = [] fieldList = gp.listfields(inputValue) field = fieldList.next() while field: fieldNamesList.append(field.name) field = fieldList.next() searchRows = gp.SearchCursor(inputValue, whereClause) searchRow = searchRows.next() rowCount = 1 recordCount = int(gp.GetCount_management(inputValue)) if int(numberOfRecordsToList) > recordCount: numberOfRecordsToList = recordCount while rowCount <= int(numberOfRecordsToList): print "RECORD #" + str(rowCount) print "-" * 100 for fieldName in fieldNamesList: try: print fieldName + ": " + str(searchRow.getvalue(fieldName)) except: print fieldName + ": !?!" print "" print "" rowCount = rowCount + 1 searchRow = searchRows.next() del searchRow del searchRows print "" print "" print "LISTED " + str(numberOfRecordsToList) + " RECORDS" else: print "ERROR: " + inputValue + " does not exist!"
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
