Is it possible to represent water in motion, a river for example? Thank you Pedro Oliveira
Hi Pedro
Yes you can. There´s two options:
1. Choose one polygon and add to the end of the name " __water " : example myriver__water
A sample here http://bit.ly/2EWMpSR
2. Option two : Use the rule WaterMaterial.cga available on http://www.arcgis.com/home/item.html?id=067950a3a1f44129a10b3a458802e450
Thank you, it worked.
greetings
Hi there,Could you allow us access to download the cga file? It says that we don't have permission to access.Thank you sir!
/** * File: WaterMaterial.cga * Created: 30 May 2013 19:24:39 GMT * Author: Craig */
version "2013.1"
// A simple water texture rule with 5 different types - different colors, wave heights & speeds
@Order(1) @Range("River","Stream","Pond","Lake","Ocean")attr Water_Type = "River"
@Range(0, 1.0)@Order(2)attr r = .44@Range(0, 1.0)@Order(3)attr g = .55@Range(0, 1.0)@Order(4)attr b = .44
@StartRuleWater -->// __waterparams_scale_speed case Water_Type == "River" : set(material.name, "river__water__waterparams_5_10") color(.44,.55,.44) case Water_Type == "Stream" : set(material.name, "river__water__waterparams_5_30") color(.44,.55,.44) case Water_Type == "Pond" : set(material.name, "river__water__waterparams_1_3") color(.2,.4,.45) case Water_Type == "Lake" : set(material.name, "river__water__waterparams_4_8") color(.2,.4,.45) case Water_Type == "Ocean" : set(material.name, "river__water__waterparams_15_20") color(.2,.4,.45) else: X.
