ArcSDE 10.1 for SQL Server Build 679 Thu Apr 5 11:43:21 2012 Layer Administration Utility ----------------------------------------------------- ---------------------------------------------------------------- Database : MYDB Table Owner : DBO Table Name : TESTSIMPLE Spatial Column : SHAPE Layer id : 2 Entities : nac+ Layer Type : In-Line Spatial Type I/O Mode : NORMAL Autolocking : Enabled Precision : High User Privileges : SELECT, UPDATE, INSERT, DELETE Layer Configuration: DEFAULTS
ArcSDE 10.1 for Oracle11g Build 679 Thu Apr 5 11:43:21 2012 Layer Administration Utility ----------------------------------------------------- ---------------------------------------------------------------- Table Owner : SDE Table Name : TESTSIMPLE Spatial Column : SHAPE Layer id : 13 Entities : nac+ Layer Type : Extended SQL Type I/O Mode : NORMAL Autolocking : Enabled Precision : High User Privileges : SELECT, UPDATE, INSERT, DELETE Layer Configuration: DEFAULTS
The 'sdelayer -o describe' tool does not give me any information about views.
Messages ... ERROR 001399: Views are not supported. Failed to execute (RegisterWithGeodatabase). Failed at Mon Jan 14 16:02:34 2013 (Elapsed Time: 0,00 seconds)
Did anyone ever find a solution to this? WE just ran into this (SDE 10.2.2 on Oracle11g)
If the the layer you are using is a query layer you need to enable the St_Geometry library on Oracle Server.
Configure the extproc to access ST_Geometry in Oracle—Help | ArcGIS Desktop
