This fix will be part of the next release of the ArcGIS Viewer for Flex.One work-around that might help you in the meantime (if you're not OK with using fewer fields, nor with compiling the source code), is to use the <description> tag.From the documentation on Pop-up configuration files:"By default the pop-up window shows the visible fields in a key-value styled table. Alternatively, you can use the <description> tag to present it in a different manner, for example in a sentence or paragraph structure"http://help.arcgis.com/en/webapps/flexviewer/help/#/Pop_up_configuration_files/01m30000002q000000/
<configuration> <title>{NAME}</title> <description> <![CDATA[<b>Hurricane {NAME}</b> was a <i>category {CAT}</i> hurricane that occurred in {BASIN} on {TRACK_DATE}. It had a wind speed of {WIND_KTS} knots.]]> </description> <fields> <field name="NAME"/> <field name="WIND_KTS"/> <field name="CAT"/> <field name="BASIN"/> <field name="TRACK_DATE"> <format dateformat="shortDateShortTime"/> </field> </fields> </configuration>
<configuration> <title>{OwnershipRecords.OWNER}</title> <description> <![CDATA [[Parcel ID: {OwnershipRecords.PID} <br> Owner: {OwnershipRecords.OWNER} <br> Mailing Address: {OwnershipRecords.MAILADDRES} <br>]> </description> <fields> <field name="OwnershipRecords.PID" alias="Parcel ID" visible="true"/> <field name="OwnershipRecords.OWNER" alias="Owner" visible="true"/> <field name="OwnershipRecords.MAILADDRES" alias="Mailing Address" visible="true"/> <field name="OwnershipRecords.MAILCITY" alias="Mailing City" visible="true"/> <field name="OwnershipRecords.MAILST" alias="Mailing State" visible="true"/> <field name="OwnershipRecords.MAILZIP" alias="Mailing Zip Code" visible="true"/> <field name="OwnershipRecords.LOT" alias="Lot" visible="true"/> <field name="OwnershipRecords.BLK" alias="Block" visible="true"/> <field name="OwnershipRecords.TRACT" alias="Legal Description" visible="true"/> <field name="Subdiv code table.Subdivisio" alias="Subdivision" visible="true"/> <field name="OwnershipRecords.SEC" alias="Section" visible="true"/> <field name="OwnershipRecords.TWP" alias="Township" visible="true"/> <field name="OwnershipRecords.RNG" alias="Range" visible="true"/> <field name="OwnershipRecords.CALCACRES" alias="Acres" visible="true"/> <field name="OwnershipRecords.PROPNUM" alias="Number" visible="true"/> <field name="OwnershipRecords.PROPDIR" alias="Direction" visible="true"/> <field name="OwnershipRecords.PROPST" alias="Street" visible="true"/> <field name="OwnershipRecords.LOTWIDTH" alias="Lot Width" visible="true"/> <field name="OwnershipRecords.LOTDEPTH" alias="Lot Depth" visible="true"/> </fields> <showattachments>true</showattachments> </configuration>
Use either <description> or <fields> for the main content.
<configuration> <title>{OwnershipRecords.OWNER}</title> <description> <![CDATA [[Parcel ID: {OwnershipRecords.PID} <br> Owner: {OwnershipRecords.OWNER} <br> Mailing Address: {OwnershipRecords.MAILADDRES} <br> Continue to add all your fields here: {OwnershipRecords.???} <br>]]> </description> <fields> <field name="OwnershipRecords.PID" /> <field name="OwnershipRecords.OWNER" /> <field name="OwnershipRecords.MAILADDRES" /> <field name="OwnershipRecords.MAILCITY" /> <field name="OwnershipRecords.MAILST" /> <field name="OwnershipRecords.MAILZIP" /> <field name="OwnershipRecords.LOT" /> <field name="OwnershipRecords.BLK" /> <field name="OwnershipRecords.TRACT" /> <field name="Subdiv code table.Subdivisio" /> <field name="OwnershipRecords.SEC" /> <field name="OwnershipRecords.TWP" /> <field name="OwnershipRecords.RNG" /> <field name="OwnershipRecords.CALCACRES" /> <field name="OwnershipRecords.PROPNUM" /> <field name="OwnershipRecords.PROPDIR" /> <field name="OwnershipRecords.PROPST" /> <field name="OwnershipRecords.LOTWIDTH" /> <field name="OwnershipRecords.LOTDEPTH" /> </fields> <showattachments>true</showattachments> </configuration>
<?xml version="1.0" ?> <configuration> <title>{OwnershipRecords.OWNER}</title> <description> <![CDATA [Parcel ID: {OwnershipRecords.PID} <br> Owner: {OwnershipRecords.OWNER} <br> Mailing Address: {OwnershipRecords.MAILADDRES} <br> Continue to add all your fields here: {OwnershipRecords.???} <br>]]> </description> <fields> <field name="OwnershipRecords.PID" /> <field name="OwnershipRecords.OWNER" /> <field name="OwnershipRecords.MAILADDRES" /> <field name="OwnershipRecords.MAILCITY" /> <field name="OwnershipRecords.MAILST" /> <field name="OwnershipRecords.MAILZIP" /> <field name="OwnershipRecords.LOT" /> <field name="OwnershipRecords.BLK" /> <field name="OwnershipRecords.TRACT" /> <field name="Subdiv code table.Subdivisio" /> <!-- I am wondering about the above field name is that correct? --> <field name="OwnershipRecords.SEC" /> <field name="OwnershipRecords.TWP" /> <field name="OwnershipRecords.RNG" /> <field name="OwnershipRecords.CALCACRES" /> <field name="OwnershipRecords.PROPNUM" /> <field name="OwnershipRecords.PROPDIR" /> <field name="OwnershipRecords.PROPST" /> <field name="OwnershipRecords.LOTWIDTH" /> <field name="OwnershipRecords.LOTDEPTH" /> </fields> <showattachments>true</showattachments> </configuration>
<configuration> <title>{OwnershipRecords.OWNER}</title> <description> <![CDATA [Parcel ID: {OwnershipRecords.PID} <br> Owner: {OwnershipRecords.OWNER} <br> Mailing Address: {OwnershipRecords.MAILADDRES} ]] </description> <fields> <field name="OwnershipRecords.PID"/> <field name="OwnershipRecords.OWNER"/> <field name="OwnershipRecords.MAILADDRES"/> <field name="OwnershipRecords.MAILCITY"/> <field name="OwnershipRecords.MAILST"/> <field name="OwnershipRecords.MAILZIP"/> <field name="OwnershipRecords.LOT"/> <field name="OwnershipRecords.BLK"/> <field name="OwnershipRecords.TRACT"/> <field name="Subdiv code table.Subdivisio"/> <field name="OwnershipRecords.SEC"/> <field name="OwnershipRecords.TWP"/> <field name="OwnershipRecords.RNG"/> <field name="OwnershipRecords.CALCACRES"/> <field name="OwnershipRecords.PROPNUM"/> <field name="OwnershipRecords.PROPDIR"/> <field name="OwnershipRecords.PROPST"/> <field name="OwnershipRecords.LOTWIDTH"/> <field name="OwnershipRecords.LOTDEPTH"/> </fields> <showattachments>true</showattachments> </configuration>
<?xml version="1.0" ?> <configuration> <title>{OwnershipRecords.OWNER}</title> <description> <![CDATA [Parcel ID: {OwnershipRecords.PID} <br> Owner: {OwnershipRecords.OWNER} <br> Mailing Address: {OwnershipRecords.MAILADDRES} ]]> </description> <fields> <field name="OwnershipRecords.PID"/> <field name="OwnershipRecords.OWNER"/> <field name="OwnershipRecords.MAILADDRES"/> <field name="OwnershipRecords.MAILCITY"/> <field name="OwnershipRecords.MAILST"/> <field name="OwnershipRecords.MAILZIP"/> <field name="OwnershipRecords.LOT"/> <field name="OwnershipRecords.BLK"/> <field name="OwnershipRecords.TRACT"/> <field name="Subdiv code table.Subdivisio"/> <field name="OwnershipRecords.SEC"/> <field name="OwnershipRecords.TWP"/> <field name="OwnershipRecords.RNG"/> <field name="OwnershipRecords.CALCACRES"/> <field name="OwnershipRecords.PROPNUM"/> <field name="OwnershipRecords.PROPDIR"/> <field name="OwnershipRecords.PROPST"/> <field name="OwnershipRecords.LOTWIDTH"/> <field name="OwnershipRecords.LOTDEPTH"/> </fields> <showattachments>true</showattachments> </configuration>
Thanks Dasa, finally got it to work. Its funny how one space or missing bracket can mess the whole thing up. One other question. Apparently the description also honors carriage returns as the <br> tag added an extra space. Does anyone know a way to make it do single space, the carriage return still leaves it as double space, although this is not a huge problem, it would help the overall size of the popup. Now, that I have that space gone, I think (other than the typing, formatting) I actually like this better as there is more control over how it displays.
Thanks Dasa,I had not yet worked with custom skins before so it took a little while to understand how to apply what was described in the API documentation to the viewer. Once I put the the new skin file in the com.esri.viewer\skins folder and the reference in the defaults.css file the fix worked great.Thank you,Jay
<description><![CDATA[Bluff Level: {BluffLevel}<br>Failure Date: {FailureDate}<br>Description: {Description}<br>Elevation: {Elevation} ft<br>USACE Reach: {USACE_Reach}<br>Image: <a href="http://gisweb:9231/bluffexplorer/bluff_photos/bluff_failure/{Picture}.jpg"><u>{Picture}</u></a>]]></description>
Adding to what Jay said:Once you copy the PopUpRenderSkin.mxml into the com.esri.viewer.skins folderadd the following to the defaults.css file in src->default packageesri|PopUpRenderer{ skinClass:ClassReference("com.esri.viewer.skins.PopUpRendererSkin")}compile the project and runSubu
For my <description>, I just use one long line of code with <br> tags between each new lineThis is a quick workaround.Thanks
