I have a layer with data. I had published the layer as service and consumed in WAB.I had added EDIT widget to edit the value and it working fine. Now I want to take print out with map showing with updated value [displayData.png].
I tried with Print widget which prints only the map and Point.
Mathan,
Yes and follow rscheitlin's instructions on the modifications. However, the format of the online files are quite confusing, so be care and edit a copy rather than the original.
Baba
Hi Mathan,
What version of WAB (ArcGIS online or Dev Edition)?, if Dev then have a look at this "Answered" question here:
https://community.esri.com/thread/184939-printing-popup-contents
Else if Online then that is not part of the functionality of the print widget
Right now, I using WAB - Arc GIS Online. But I had setup dev environment [Node.js/Atom IDE].
In my understanding, If I need customized print functionality, I have to download the app which created WAB - ArcGIS Online, Open in Atom IDE and modify and relaunch again in AGOL.
Am I right?
