As of yesterday we were told according to ESRI tech support as reported in this bug, NIM097491 and tests we have been running ADFS on does not work on the Collector app. Can you help to Clarify?
Thankx
Frank
ADFS Enterprise logins will work in the released version of Collector 10.2.5. I will update the NIM and close it out.
Thanks
Russ
OK, I have sent a note to the tech however our tests indicate a successful login using our Corp AD account on AGOL via browser, IE and Firefox, and “no” successful login on Collector 10.2.5 using same account. We are presented with the option to use the account in Collector but never given a form based window to put any credentials. The app just spins and eventually returns to the Collector splash page. Are we missing some expected behavior?
Are you using iOS or Android? Are you able to sign in using the browser on the device?
Ok, well after some review of the ADFS configuration on our network and your posting that the "bug" should be closed as well as successful ADFS logins we have determined that our ADFS is not exposed externally. We are now reviewing this and hoping to apply the required changes. I will followup with our final verdict but anticipate the logins to work once the ADFS is open externally. I am glad I reached out to you since the ESRI tech closed the case pretty much immediately due to the NIM Error still being open.
We have corrected our ADFS configuration and can now access our services without issues inside Collector. Since we are using a reverse proxy on our network this required additional IIS permissions to be set correctly allowing internal and external access to the AD stores. Again thanks for following up since ESRI Tech support had incorrect information on the bug.
Thanks for updating this thread.
Cheers
hi Russell,
We have enabled Enterprise Login's within our University but are unable to log in via ArcGIS Collector (10.2.7 iOS).
So i feel like this is related to our Shibboleth / LDAP configuration, but i've been unable to find any specifics online or
within geonet. We can access our accounts via Enterprise Logins if we're using a web browser (desktop) but not
from mobile apps or the iOS Safari browser.
Our campus security team is looking into it but any tips you may have would be greatly appreciated.
best regards,
brian culpepper
What error are you seeing with Shibboleth enterprise logins? We have one known issue with Shibboleth logins right now that ends up preventing the credentials being accepted and an error page is displayed.
Russ,
The message we get says: You have asked to log in to: Unspecified Service Provider
Our enterprise logins work from a desktop web browser, so we only see this error message when
we attempt to log in from the ArcGIS Collector app (iOS 8.0.2). we've not attempted connections
from Android or other iOS versions yet.
Our security team initially thought the issue was related to Collector not redirecting to an https://
url when prompting for our university credentials. Any ideas?
thank you Russ!!
best,
