Is there an example on how to get drivetime polygons for a time greater than 15 minutes using esri.leaflet?
I can use the sample code pretty much as is to generate single polygons for any time up to 15 minutes,
but greater than that the response seems to default to 5 minutes. I have a routine that gives me a token based on
the client ID and secret from the app I registered with Esri and use this as shown in code below. I am thinking it is an
authentication problem dis-allowing times greater than 15 minutes but I am not sure. If anyone has a suggestion PLEASE HELP!!!
Thanks in advance.
I create a service as follows:
var gpService = L.esri.GP.service({
url: "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Network/ESRI_DriveTime_US/GPServer/CreateDriveTimePolygons",
useCors: false
gpService.on('authenticationrequired', function (e) {
e.retry(esriToken);
gpService.authenticate(esriToken);
gpTask = gpService.createTask();
gpTask.token(esriToken);
driveTimes = L.featureGroup();
leafMap.addLayer(driveTimes);
Later on I call this function to create the polygon after a user enters time in minutes and clicks a button:
function drawDriveTimePolygon(lat, lon, minutes) {
driveTimes.clearLayers();
gpTask.setParam("Drive_Times", minutes);
gpTask.setParam("Input_Location", L.latLng(lat, lon));
gpTask.run(driveTimeCallback);
function driveTimeCallback(error, response, raw) {
driveTimes.addLayer(L.geoJSON(response.Output_Drive_Time_Polygons));
var points = response.Output_Drive_Time_Polygons.features[0].geometry.coordinates[0];
var arrayLength = points.length;
var vertices = [];
for (var i = 0; i < arrayLength; i++) {
vertices.push(new L.latLng(points[0], points[1]));
var polygon = new L.Polygon(vertices)
.setStyle({ color: shapeColor })
.addTo(leafMap);
