Yep - shortly after posting my original question I did exactly that - exported the feature class schema as xml, imported the schema into 10.1 SDE and then loaded the data using the Simple Data Loader. This still reported the same geometry errors, but continued loading the remaining data. I still don't fully understand why these features fail to load having been sourced from SDE and also after running Repair Geometry. They are line features and surely the minimum number of parts for a line is 1, or maybe even 0 for a null geometry. I'd still be interested if anyone explain what this error is likely to refer to?CheersJohn
