''generates object for the specified MapServerLegendClass Private Function legendClass(ByVal lclass As MapServerLegendClass) As jcLegend Dim jcLeg As New jcLegend jcLeg.label = lclass.Label ''!--you may need the line below if you webserver return a image url that is not a ''fully(qualified) url address--! ''jcLeg.url = Replace(lclass.SymbolImage.ImageURL, "calhalgis", "gis.calhouncounty.org") jcLeg.url = lclass.SymbolImage.ImageURL Return jcLeg End Function
''jcLeg.url = Replace(lclass.SymbolImage.ImageURL, "helcom03.hcdomain1.local", "maps.helcom.fi")
Manolo, In your restLegend.asmx web service application there is this function ''generates object for the specified MapServerLegendClass Private Function legendClass(ByVal lclass As MapServerLegendClass) As jcLegend Dim jcLeg As New jcLegend jcLeg.label = lclass.Label ''!--you may need the line below if you webserver return a image url that is not a ''fully(qualified) url address--! ''jcLeg.url = Replace(lclass.SymbolImage.ImageURL, "calhalgis", "gis.calhouncounty.org") jcLeg.url = lclass.SymbolImage.ImageURL Return jcLeg End FunctionSo in your case it would be ''jcLeg.url = Replace(lclass.SymbolImage.ImageURL, "helcom03.hcdomain1.local", "maps.helcom.fi")
webService.endpointURI = webService.endpointURI.replace("helcom03.hcdomain1.local","maps.helcom.fi");
<?xml version="1.0" encoding="utf-8" ?> - <rLegend xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="http://gis.calhouncounty.org/"><ServiceName>mapservices.ca</ServiceName> - <Layers>- <jLayers><layerId>0</layerId> <layerName>FireSmartProperties</layerName> <lMaxScale>0</lMaxScale> <lMinScale>0</lMinScale> - <clegend>- <jcLegend><label>Low < 21</label> <url>http://mapservicesca/arcgisoutput/_ags_leg3254af0347b4430d8113341652086cd7.png</url> </jcLegend>- <jcLegend><label>Moderate 21 - 29</label> <url>http://mapservicesca/arcgisoutput/_ags_lega4e45e4d9c4346d9aeb54e360570816c.png</url> </jcLegend>- <jcLegend><label>High 30 - 35</label> <url>http://mapservicesca/arcgisoutput/_ags_legeb089bbc1d9840f78c80a0b5e67ab36e.png</url> </jcLegend>- <jcLegend><label>Extreme > 35</label> <url>http://mapservicesca/arcgisoutput/_ags_legc9efad23d0a147168d33433b67f26594.png</url> </jcLegend></clegend></jLayers></Layers></rLegend>
Private Function legendClass(ByVal lclass As MapServerLegendClass) As jcLegendDim jcLeg As New jcLegendjcLeg.label = lclass.Label''!--you may need the line below if you webserver return a image url that is not a ''fully(qualified) url address--!jcLeg.url = Replace(lclass.SymbolImage.ImageURL, "mapservicesca", "mapservices.ca")jcLeg.url = lclass.SymbolImage.ImageURLReturn jcLegEnd Function
''generates object for the specified MapServerLegendClassPrivateFunction legendClass(ByVal lclass As MapServerLegendClass) As jcLegendDim jcLeg AsNew jcLegendjcLeg.label = lclass.Label''!--you may need the line below if you webserver return a image url that is not a ''fully(qualified) url address--!jcLeg.url = Replace(lclass.SymbolImage.ImageURL, "mapservicesca", "mapservices.ca")jcLeg.url = lclass.SymbolImage.ImageURLReturn jcLegEndFunction
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
